Turbo Wheels
I've got a pair of Fulcrum Racing 7's, rear has a worn rim on one side, the other side is also worn but to the same extent - the wear indicator is still visible (just) on both.
The front rim is worn but the wear indicator is still visible. The stickers on both rims are shot, but they can be de-stickered with a hairdryer (I've not got round to doing it but it was a plan I had). The bearings are great and the freehub has just been serviced so they're running great.
I'm saying for turbo use because the rims are worn, the rest of the components are fine.
£45ono posted (courier) for the pair
More pics of everything
2 x RT 52 Discs
Worn but not worn out, centrelock, I only have 1 lock ring for some reason though. One disc has a bit of a brown stain, not sure what from, they were working fine when removed.
£10ono posted
FSA XC 190 Seat Post
Very light, only 228g! Fully boxed, 31.6 diam, 350mm long, zero setback. It has a 5mm mark (as shown on a pic) from where I put it in the frame for the first and only time, otherwise perfect condition!
£20ono posted
Easton EA90 stem, 120mm
Some slight wear to the graphic as shown, this is where my Garmin mount has been. It's unnoticeable if you have a stem-mounted computer/GPS
http://www.bikeradar.com/gear/category/ ... stem-24350
£25ono posted
2 x RT 52 Discs
£10ono posted
£20ono posted
£25ono posted
