FS Ebay 2008 Campagnolo Veloce Ultra Torque Crankset.
nuovo_record
and if i read correctly it also includes the bearing cups too?
Tel
Kent
Nice. I wish I had more money...
Two things:
1. Do the ultra torque systems work on standard bottom bracket shell or is it different altogether (hope that makes sense)
2. The thing with adding Buy It Now and a auction is that when someone bids the buy it now option goes, so the extra money you paid for adding BIN isn't worth it...unless someone does use the BIN option of course, but personally if I see something that I like I'll put in a minimum bid to get rid of the BIN option and then see how things go.
I
iGaz
Cornwall
I know the BIN option costs a bit more, but I have sold alot of stuff either, sometimes more than what I had the buy it now down for!!
The Ultra Torque system I believe uses a special BB, I'm not sure how it works, but it never creaks!!
Two things:
The cups fit any english threaded B/B.The cranks are each joined to half of the shaft via a bearing assembly inside the cup then mated together with a bolt(this requires a humungous allen key).
I have a Mirage UT which works great bit has two slight problems
1) The ends are open so gets a lot of crap in - I just put two plastic covers over.
2) The bolt can work loose so has to be checked regularly especially after the first time out.
Proto
No!
ColinJ
Puzzle game procrastinator!
