oliglynn
- Oxfordshire
Have noticed there's a tiny bit of lateral play on my relatively new racing 5's. They've done ~1000 miles at a guess. In certain positions in its rotation I can wiggle the wheel from side to side at the rim, and it moves positively at the bearings.
Have taken it apart (taken the axle out) and had a look at the bearings (stuck the axle in with the close fitting bush pointing the other way and gave it a wiggle). The bearing on one side seemed a tiny fraction looser (I could wiggle the axle a tiny bit more) - but not knowing much about wheel bearings, was not sure if either of the bearings are shot or not, or whether the axle had come a bit loose or how tightly to re-assemble.
I re-assembled to the closest free-running fit (bearings not compressed), and the play is still there. I don't want to over-tighten it as it gets stiff and I don't know if this will damage the bearings.
Sooo... any advice on how to know if bearings are gone, and how tight to fit the axle would be appreciated!
