summerdays
Cycling in the sun
- Bristol
I have got Trans - X Security Skewers on both my front and rear wheels. However I seem to have a problem with my front one coming loose gradually. I ought to check the wheel every time I go out but usually the first I'm aware is a slight noise/movement on braking and when I check the wheel I can wobble it from side to side a small amount.
I'm getting Mr Summerdays to tighten the skewer so its not my strength that is the issue (unless I get a puncture of course - then I'll have to do the damsel in distress if I can't loosen it
Is it anything to do with the type of skewer or do front wheels tend to work themselves loose. Or is there something else I should be looking at?
For example it was tightened about 1 month ago and I've done about 250 miles since then and I noticed it loose again yesterday. Its not a major problem but I didn't seem to have this problem last year.
).Is it anything to do with the type of skewer or do front wheels tend to work themselves loose. Or is there something else I should be looking at?
