Garry A
Calibrating.....
- Grangemouth
Hello, I have a problem with my front derailleur shifting. I have a Sora compact double on my 2015 Giant defy and it won't stay on the top setting on the big ring, it keeps popping down to the trim setting. I replaced the cables but this didn't help, sprayed gt 85 into the shifter but that made no difference. The front derailleur has been cleaned and lubed. It's all been set up according to the Park tools video. The shifter goes through all the settings until cable tension is added then it gives up. Interestingly if I press on the derailleur cable arm when shifting up and hold it for a second, it stays in the top position until I touch the shifter lever.
Is my shifter just done? I wouldn't say I've done super high mileage.
Thanks, Garry.
Thanks, Garry.
