Brand new Fratello picked up Wed
Soon after leaving the shop there's a slight scraping/creaking noise from the front crank, seems to be the cage touching the chain for a small section of the rotation, gets worse when the chain line is to the ends of the casette but always there, happens in both chain rings
There's a barrel adjuster that I've fiddlde with and I've tweaked the High Low stops without joy, the cage is very narrow and I'm almost certain that there's lateral movement of the chain as it passes through the chain, only slight but that's what causing it given the narrowness of the cage
What might cause that given the bike is brand new and not cheap?
ta
ta
