Nozzer
- Gloucester
On my cannondale f4oo, the front mech has stopped working, when i change gear the cable just goes all floppy, has the mech seized?
Just looking at different front mech's, how will i know what size etc to get, looking on chain reaction and there are loads of different sizes. Bike is 2007 cannondale F4
As I said it's a MTB mech.Indeed they do sell them in different sizes. If you don't have a vernier (sold in Poundland) per picture below for measuring tube diameter, you can wind a piece of thin light coloured cotton a few times tightly around the downtube near the front mech, and use a thin marker pen or some such to draw a thin line vertically down across them. When you have unwound the cotton measure the distance between adjacent marks in mm (should all be roughly equal if done right) and divide by 3.14. That would be the diameter of your downtube (because tube circumference is 3.14 times diameter) and is the size for which front mechs are sold.
Downtubes generally come in 28.6mm, 31.8mm or 34.9mm which are approx 10% apart so the above method should be accurate enough to figure out which one you have/need.
