IanT
http://www.sprocketwaffle.co.uk
Lately, the gears on my Carerra TDF have become noisy - with the chain rubbing the front derailleur. After diligently watching numerous YouTube tutorials and, armed with my Haynes Bike Book and downloaded Shimano servicing info, I set about adjusting the front mech.
I'm confident that the height and alignment are now both correct (which they were not before - as fitted from new, it was angled distinctly inward). After adjusting both limit screws and cable tension, the shifting is better - although, I notice that the shift from the small to the large chainring, the shift you sometimes have to stop pedalling for the shift to happen. It's odd, because, with the bike in the workstand, the shift is seamless. I can only imagine that the frame flexes, when loaded - altering the cable tension?
One thing has got me wondering, though, is the front outer chainring. It appears that a few of the teeth are slightly squared-off. Now, the bike has only covered about 200 miles from new - so I'm sure it's not wear. I do know that some chainringa have a ramped section to ease shifting - so I wonder if this is what I'm seeing? I have attached a photo of the offending few teeth and would be very grateful for any opinions or advice.
Thanks.
Ian.
Thanks.
Ian.
