Hi
I'm having some difficulties replacing the gear cable on the front mech of my carbon Scott Solace 20 and hoping for some guidance!
The images below show the relevant access points to the frame. The insert at the headstock is a twin plug for both the front and rear derailleur.
The plug at the base of the frame is a single moulding for the cable guides for front and rear.
Unfortunately the inner for the front mech has been fully removed so the only way to proceed will be a partial dismantle.
My thoughts are as follows:-
The design appears to indicate that both the front and rear cables will need to be replaced at the same time.
In order to fish the cables from within the frame the bottom plug will need to be removed. But as the plug is a one-piece the rear cable will also need to be undone at the mech to provide enough slack.
Unfortunately to provide sufficient slack the inner rear will need to pass through the outer at the derailleur and will undoubtedly fray meaning that I may as well replace that one too...
I've never replaced cables on a carbon frame before and would welcome some confirmation that I'm on the right track. Any other thoughts would be appreciated.
I've seen a couple of videos on YouTube but there are so many different designs there doesn't seem to be a definitive solution.
Many thanks
Gary
Many thanks
Gary
