Kestevan
Last of the Summer Winos
- Holmfirth.
I have a slight problem with the adjustment on the front mech (Tiagra double).
When I'm running in the lowest gear, the chain is "slightly" rubbing on the fron cage. If I move the adjustment screw so that the chain rub stops, then I cant change down from the outer front ring reliably.
All the other gears appear ok, and if you push the front cage back in to the frame slightly with your fingers the rubbing stops. It looks like its just not moving back far enough onto the stop if that makes sense.
Any ideas on how to cure this?
Cheers
Cheers
