SquareDaff
- Doncaster, South Yorkshire
Recently changed out the stem on the road bike. Fixed the new one vertically tight against the spaces so that no play was evident between the forks and frame but after riding for 20 or so miles then some play is evident again!! This has happened a couple of times now - I keep removing the issue on the bikes regular maintenance (i.e. by loosening the stem and pushing it down to remove play - then retightening).
Is there something I'm not doing? I always thought movement between the fork and frame was a bad thing.
- thankjs for your help - will check out tonight. Hopefully, as your say, it just requires a couple of minor adjustments.
