Front fork lock out
PaulSecteur
No longer a Specialized fanboy
Hi,
Did a bit of a ride yesterday on my Kraken, as it was a road ride I used the fork lockout.
When this is engaged The forks can still be compressed slightly, its not a mechanical solid lock out.
However, after the ride (about 10 mins after) I relesed the fork lock and the forks extended by about an inch, maybe a bit more. Should that happen?
Cubist
Still wavin'
Ovver 'thill
Paulkraken
What sort of forks are they? If I didn't know better I'd suggest you had actually wound the preload up to max whilst sat on the bike.
Armegatron
I have Suntour Nex 4110's and they do a similar thing. They are quite temperamental with cold and heat affecting how free they run and when turned to max preload they still have a bit of springing back to them
