Front drop out adjuster/ insert?
Hi,
My wide rimmed aero wheel is a very tight fit in a tt frame, if it sits at the top of the drop out, it rubs; if it sits a mm or two lower its fine. A problem occurs though if the skewer when riding rises to the top of the dropouts. Is it a case of just ensuring the qr is tight enough or do you get some sort of insert/adjuster which stops the skewer doing this (rising a few mm) ?
TIA
Pale Rider
My understanding is the front wheel should be fully pushed into the drop out.
If it rubs elsewhere then the wheel is not suitable for the frame.
Mobytek
Wot he said.
axl to the top of the Drop out so the fork takes the weight, not the spindle. Spindles are just there to hold the axle in, not weight bearing, which if you try and hold it on the QR you are doing - and damaging the DO the 1 / 2 mm down.
You may eb able to get stops that sit indie the DO, but realistically if your wheels too big, its too big. New fork or new rim.
Just out of interst, how does the back one fit/
Pale Rider
I know TT frames are designed for tight clearances, but I find your experience disappointing.
If a TT wheel and tyre fits the back, you are entitled to expect its matched twin to fit the front.
How old is the bike?
If it's fairly new, I would have a friendly word with the supplier.
I don't think you are entitled to anything from the warranty, but as a matter of goodwill they might help you out a bit with the cost of a front rim.
Tim Hall
Crawley
Cheers,
I'm running pro 4 Service Course 23mm, I may try a different brand or a 22mm conti attack and gain the mm that way or resign my self to a new rim in the new year.
Can't see how a new rim will help, unless you go from 700c to 650. A smaller tyre is the smart thing.
Marie Attoinette Fan
Its a second hand one I was testing but I've opted against buying it. It works well with other traditional width wheels just not my 23mm wide front wheel.
My rims are 23mm wide and traditional rims are 19mm but a new tyre is a cheaper option :okay:
Pale Rider
Makes more sense to me now.
If you consider buying another TT frame/bike, you will now have a better idea of what to look for.
