Front derailleur
NickTB
Morning all.
After breaking my rear mech hanger and replacing it, I’ve indexed the rear derailleur and that’s working fine. But I’m finding I can’t shift from the small ring to the big ring now. I’ve adjusted all limiting screws no the front derailleur and barrel adjuster and cable tension. If I pull the cable manually it’ll flick onto the big ring. As soon as I let go of the cable, the derailleur skips back to its old position. The shifter itself sometimes feels a bit ‘soft’ and other times it’s fine. Anything glaring I’m missing?
Thanks
Nick
lazybloke
Priest of the cult of Chris Rea
Leafy Surrey
Slack cable?
NickTB
NickTB
I’ve just noticed the outboard screw doesn’t seem to be doing anything. I tighten the onboard and the derailleur moves in and out. There’s no movement at all when I tighten or loosen the outboard one
