Fifelad
- Carnock,Fife
On a 70 mile ride today everything was working sweet, but on a couple of occasions the chain wouldn’t budge from the small ring to the big ring, the derailleur moved but not the chain. It’s a new cable. Slick as anything on the next attempt. Baffling and infuriating. It’s a new chain and chain rings are in good nick. The only thing I can think off is cable tension, I’ve tweaked the inline barrel adjuster to tighten the cable while on the ride. Could the cable have done with being a bit tighter in the first place when I put the cable in and first clamped it in ? I did it hand tight and there is only so much purchase I can’t get by hand, I don’t want to pull it with pliers if I can help it Suggestions please ?
