Hi all, I came off my new road bike earlier today and none of the gears were shifting at all after. I've sorted the rear gears nicely, however had alot of chain rub even in the medium rings so started to adjust the front deraileur position and play with the limit screws.
Not sure if something happened in the fall or after when I've adjusted something, but when I use the shifter now the cable moves whilst the front deraileur (Shimano Claris) stays still. I can get it to move manually by pushing it. The cable is interally routed, haven't checked the cable at the shifter end as I don't want to take the bar tape off unless I need to?
I'm hoping something is just out of alignment rather than broken? Any ideas?
