If it's pushing it off the small ring, I'd suggest the adjuster screw needs a tweak to limit the travel.
Why did you adjust it in the first place?
Make sure it's parallel to the chain rings and at the right height. See
here for a guide.
Could also be sticky cables - shifting from big to small relies on the spring doing the work. If the cable is gunked up, that's extra resistance the spring needs to overcome.
