merlin321
I am trying to remove the front wheel on my SCR2. When I lift the cam on the calliper that the brake cable runs through, there is no movement at all to open out the brakes.
There is an allen headed bolt that runs through the other side of the calliper with a nut on the end. I can undo the nut at the back but the allen key end will not budge. Is it supposed to?
I have wd40`d the lot and left it to soak but it seems to make no difference.
The bike if 5 months old.
Can anybody offer any advise because this is getting on my wick now.
I broke the top of the core from the Presta valve off this morning and although it held air for todays commute, I don`t want to push my luck again tomorrow.
Cheers.
Cheers.
