Time Waster
I am wondering if there is a small in size but high enough in lumens front light, say about 500 lumens. It is for commuting on a brompton but when not used I want to fit it inside a tiny frame bag that goes into the triangle. This is about 9.5cm x about 13cm and 5 cm deep triangular bag.
I will probably leave the rear laserlight on the bike but if possible might try to fit both lights in there. Or might look for a 100 ish lumens rear light that is smaller to fit in as well.
Basically I want to carry them as an emergency light but might just end up using them all the time and store the lights in there when folded and locked up at work. So am looking for ideas. I am not up on lights. Assume cateye are alright still??
PS don't go to the "carry it with you" place as that is not possible for all cases and it is not in mine. I have to lock it in a secure place outside for some very obvious reasons if you worked where I do.
(yeah whatevs)
