friction shifting
lip03
beds/ london
can anyone point me in the right direction re friction shifting.... i.e setting up from scratch, have stripped an old rusty set to clean and need a comprehensive guide to putting it all back so it shifts well,
TIA Phill
Rob3rt
Man or Moose!
Manchester
Put the cable in and tighten the bolt... what else is there too friction shifting, that's the joy of it!
Dogtrousers
Kilometre nibbler
Not sure what you're after. One of my bikes is friction shift and I put it together so I should be able to answer questions, but there was nothing to it.
What do you mean by "set"? Set of levers?
All it requires is to have the cable set so there's hardly any slack in the full forward (top gear) position and have the end stops set right on the derailleurs. Then ensure the levers have enough tension in them so they don't slip - mine have butterfly nuts on them that I check they are finger tight each time I ride. And you're away.
It's beautiful and foolproof.
Or are you actually asking a more complex question and I've missed the point?
HovR
Plymouth
Friction shifting is dead simple. Start by cleaning and lightly lubricating all pivots, springs etc on the dérailleur and shifter, and ensuring that any cable guides are clean from dirt and debris. You don't want any rust, especially on the friction surfaces, otherwise it won't be smooth at all. Get to work with some wire wool or fine grit sand paper and get everything nice and shiny again.
Get those parts attached to your bike again, and reassemble with new decent quality gear cables, again lightly lubricated, and cut to the appropriate length. Assuming the old cables were the correct length, you can use those as a guide. You want to avoid any tight turns in the cable, whilst ensuring it isn't excessively long.
When fitting the cable ensure that the chain is on both smallest cogs (front and rear), and that the shifters are pushed all the way forward (so none of their travel is used). When locking the cable in to place on the dérailleur ensure that there isn't any excess slack in the cable. You can adjust out small amounts of slack with barrel adjusters if present.
Once the cable pinch bolt is tightened down and everything is locked in to place, just set the limits on your dérailleurs, set the friction on the shifters to your preference (tight enough that the gears don't auto change under pressure, but not too tight that you can't shift smoothly), and you're pretty much done!
lip03
lip03
beds/ london
that is brilliant, cheers I know it is a very simple system but that has helped no end.
Phill
