rajibul123
For the last couple of days, I've been cycling my fixie bike (which has a flip flop hub and I use the freewheel end) and I suddenly peddling stopped responding with the back wheel completely. I gave the freewheel a clean with soapy water but no improvement. I thought if I took the freewheel off completely and gave it a thorough clean with a penetrating oil may help. But the process to take it off has me worried I've broken the whole back end. After initially looking at the freewheel, I saw no obvious freewheel remover tool I could use. I thought maybe taking off the nut in the first image will reveal some sort of notch or something but I ended up taking off the wheel hub for flip sake. Little balls and grease came out of both ends of the wheel. Its a lil bent right now cos I genuinely dont know how to get these balls back in. I think I can juss apply new grease and put new balls into the wheel hub and that should do the trick but WHAT ON EARTH IS THAT FREEWHEEL AND HOW DO I TAKE IT OFF. Please help, Im so lost. Thank youuu
