Jimmy Doug
If you know what's good for you ...
I've started hearing a gritty noise when freewheeling. Thanks to the god-like Sheldon, I found that I should lubricate every year with a medium oil by simply pouring it into the freehub with the bike on its side. But what constitutes a medium oil? I know there exists something called Phil's Tanacious Oil, but it's quite expensive and has only limited use. What else can I use? In my garage right now I have chain oil (normal and wet), B'Twin spray grease (which seems very light), B'twin teflon grease (which is very thick), 3 in 1, diesel engine oil, UB40 (Yes, I know it's not really a lubricant!) Could any of these oils do the trick? If not, what about chainsaw oil?
. Thanks for prompting me to correct my misunderstanding.
