Freehub tool recommendations for Giant SR2 wheel
dennetti
Bristol
Hi. I'm trying to remove the freehub from my Giant SR2 wheel. After removing the cassette and axle, it looks like I need to get a long-reach castelated tool into the wheel to remove the freehub. Looks about 10-12mm sort of size. Could someone confirm what tool I need please as I can't seem to find what I need. Thanks a lot.
dennetti
dennetti
Bristol
sure, I will try. I tried a 10mm allen key, but no good. I then noticed that a round tool with notches cut out of it would work.
dennetti
dennetti
Bristol
556905
556906
The top image shows what I'm reffering to. Cheers
iluvmybike
The allen key required could be a 10mm, 11mm or 12mm and likely will be inserted from the other side(NDS) to remove the freehub body. If the tool does insert from NDS best pout it ina vice and use the wheel as the lever to remove - they can be quite tight. Make sure the allen key is a good fit as easy to round it off!
dennetti
dennetti
Bristol
A bonus question please: anyone know what freehub I need for this wheel please? Hopefully it will have a model number on it. Thanks
andrew_s
Gloucester
I see. I don't need a star shaped key then. Just a bigger allen key should engage with those slots?
Yes.
It's a bi-hex socket - uses an allen key, but the allen key fits every 30 degrees of rotation using the alternative slots, and it leaves a slightly bigger hole down the middle for the wheel axle.
An allen key fits properly in every other slot, a square driver fits sort of in every 3rd slot.
dennetti
dennetti
Bristol
Thanks, I bought an 11m allen key and it worked perfectly. Conventional thread, and it wasn't too tight. Just needto find a replacement freehub now.
dennetti
dennetti
Bristol
Cheers. I think I found what I need: Trek/Bontrager Freehub Body 561948. There's a lot of deifferent freehubs out there!
sherlockdowney
Did you get it out from the drive side or non-drive side and when you say conventional thread you mean lefty loosey?
I ask because I gave it my all from the drive side turning anticlockwise but it didn't budge. I have a giant TCR SL2 2021. Thanks in advance.
