Freehub Body Shimano removal
jonas2301
As my cassette is from Campagnolo, I have to change my freehub body from Shimano to Campagnolo. I already did the first steps, but the body itself (see picture) is very hard to remove. Is there anyone who has tips to facilitate this body removal?
cyberknight
Is there any reason you can't get a Shimano cassette?it would save a lot of messing about.shimano hubs if I remember rightly use a10 mm Allen key.i assume your new freehub is compatible with your wheel ?
T4tomo
To answer the question posed,it depends to a degree on the wheel hub type, but usually a large ? 10mm allen key inserted from the opposite side (non drive side) will unscrew it.
you need to ensure you have the correct Campag compatible free-hub to replace it with for your particular wheel hub, not just any old campag free hub.
