Free wheel
wolf37
Hi all i just brought a free wheel bike or fixed speed think they call it but think made mistake and should or got a geared bike are the fixed speed any good ??
russ.will
Slimboy Fat
The Fen Edge
Good for what use and which fixie?
Russell
midlife
I used to do a lot of single gear riding way back when, particularly getting to and from work / school. No need to worry about all that gear changing *and* I could track stand at the lights :smile:
Shaun
Sharky
Kent
Single speed or fixed gear can be exhilarating to ride. Need to choose the gear size so that you can just manage the steepest hills that you encounter on a regular basis, then the rest of the journey will be fun. If in a hilly area, single speed (free wheel) might be the best option as descending on a low fixed gear can be tiring and takes more skill than you might imagine.
Count the teeth on the front ring and the rear sprocket and we can advise if that is a sensible set up. Easy and cheap to get a smaller/ bigger sprocket.
Happy riding
Keith
Fixie bikes have the rear cog fixed so it (and pedals) must rotate with wheels.
Singlespeed means a rear freewheel one-speed where you can roll along without pedalling.
Some hubs have both, you flip the wheel around.
Fixies are a bike for experts and for reliability. Singlespeeds are OK in flatter areas.
W
wolf37
I got 44 on front ring and 18 on back and i have got the wheel that got cog on other side of rear wheel
Sharky
Kent
That's around a 64" gear, depending on wheel size and is within the range that most single speed riders would use. So just depends on how you find your local hills. If easy, then change the 18 to a 17 etc.
if the hills are too hard with the 18, you would need to change to a 19 or a smaller front chain wheel.
Changing sprockets is a very easy job, but you do need a special tool. A local bike shop is unlikely to charge very much for fitting and would probably be cheaper than buying the tool you need. Ask for prices.
Good luck
