shimano are 10 mm afaik just took one off my rs 11wheel with a 10mm but its seized even after soaking , the freehub on my mavics are 11 mm and i need to get one to sort it out .
You may well be right and I will stand corrected if need be, but the axle itself is 10 mm and I still have a 1/2 inch socket with 11mm hex extension here I used to use for exactly that job, hence me having been so sure it's 11.
On the aluminium Shimano axles, which were 12mm IIRC, the freehub body came off with a 14mm hex key.
