Andy in Sig
Vice President in Exile
- Sigmaringen, Germany
Does anybody know what are the best drop out arrangements for a Rohloff hub gear? As a complete innocent in this field I would have thought a backward pointing vertical arrangement but then getting the chain on would be a bugger unless you had an excentric bottom bracket arrangement. I seem to recall seeing a picture in a German mag of spring loaded steel plates which locked it into position. I guess (and it is a guess) that the biggest factor is the one sided pull on the hub which would take it out of true if it weren't held securely in place.
The question is important because if you get a flat, you want to be confident that you can remount the wheel in a true position.
