When replacing suspension forks for rigid ones you want to make sure that you get forks which are corrected for the amount of suspension you are replacing (i.e. if you are replacing 100mm suspension forks, you want to make sure your new rigid forks are corrected for this). Otherwise your headtube angle will be altered, effecting the steering of the bike, and the bottom bracket will be lowered making pedal strike more of a possibility.
If you have very low travel suspension you may get away with using regular rigid forks, although this is dependant on your frame geometry.
When you buy a new fork it won't have the crown race fitted. You can take it off your current fork using either the proper tool, or a flat bladed screwdriver and a hammer, carefully tapping the bottom lip around the whole circumference until it is free. You can either re-fit it with the proper tool, or "tap" it back on making sure not to damage the bearing surface. Your LBS will have the proper tools if you don't want to do it yourself.
You will almost certainly have to cut down the steerer tube of your new fork to the correct size (same as the old one). To do this just clamp the steerer tube carefully in a vice (might want to wrap it in a protective cloth) and cut it with a hacksaw, making sure your cut is as straight as possible.
The star nut also won't be fitted in the steerer tube. You can get a new star nut from
Halfords for under £2, probably similar at your LBS. You can fit it yourself by putting a bolt in the centre and hammering it in (making sure you are fitting it as straight as possible), or you can take it to your LBS and they will use the correct tool.
