T4tomo
So I'm in process of removing the forks, the headset looks as below. Having removed stem and spacers, you tube would have you believe, the forks drop out, or may need a pursuing tap with a mallet. However mine have another retaining thingy above the headset. The centre bit of it is a rubber seal and below that is what I assume is the centering clip / washer just above the top headset bearing
So do I just whack it with a mallet or do I somehow need to get the top piece with the writing on it off first??
The frame is about 15 years old I think, and this is first time I have removed any forks. Any knowledgeable advice appreciated
cheers.
cheers.
