Folding Microbike , any info?
Microbike
Hi , I have just bought an old folding Microbike which after a quick tyre change & puncture repair went round the block quite nicely. Rubber belt drive & pedal back rear brake. Can't seem to find out much about this well engineered machine on the net, any ideas ?
M
Microbike
Hi , quick response. I do not think it is that one although it is difficult to tell from that picture. This one has a silver anodised aluminium frame , black rubber boots over the joints, a couple of Microbike labels / stickers & one on the lower bar that says something like SHNED or SHRED . The third digit is hard to work out due to the font. Also the Microbike has no hyphen.
M
Microbike
;) That is the one, spot on apart from the colour and someone has added a front brake at some stage which I thought did not look original. Is there any technical information available on these? & thanks bye the way :sad:
M
Microbike
Your internet search skills are way ahead of mine. I asked about the spec because the only thread I could find mentioned some sort of two gear system. Only way to go was to test it out so gave it a try this morning & I could hardly believe that the little back hub incorporates the drive, freewheel , back pedal brake plus a two speed back pedal triggered two speed drive assembly. That small 12.5" wheel & it all works :?:
