robsa
- chesterfield
Hi fellas, been slowly over the past 5 month tinkering with an old rudge I got of ebay (£20) .
Stripped and re greased the bottom bracket, ok got a mushroom cotter pin but eventually got the sod out. Now, I'm fancying removing the sprocket off the sturmey dyno hub(dated Feb 1950), one its got snaggle teeth and two I live in Derbyshire,which isn't exactly flat so was going to bung a 22 tooth on. So, being the conscientious sort ive done the research.
Pop off a circlip and bobs your uncle.
Off with the wheel (pain in the arse with rod brakes) and hey presto....... No bloody circlip!
Any ideas?
I really don't want to strip it down because as my dad taught me ' if it int brok dunna fix it'
Is there a reliable sturmey mechanic within 20 mile of chesterfield? All the lbs ive been too look at me with fear and loathing as soon as I mention its a Sa hub.
Thanks for any info gang
Any ideas?
