Paul Adair
Regular
My viking giro Italian has shifter on thr Handel bars I was wandering is it a big job to put flight deck shifters on and wat would I need to buy . Help please
Depends, 7sp can be had on ebay for £20-30.Your Viking seems to have a rather strange shifting arrangement, but it should be possible to swap them out for 105 flightdeck shifters. Not sure if they are still called flightdeck though. But you will likely end up spending more than 50% of the bike's value doing it! Is it really worth it?
The 8 would work with with a 7sp cassette but it's not perfect, if it will take an 8sp cassette, they are 3.5mm wider, 0.2mm from sprocket to sprocket, it would be easier just to get an 8 speed cassette and shifters, new cables £60 should cover that, but as Vikings usually come with a 52/39 front it will be pretty high geared, the 8 speed could help there, but the rear mech might not cope.With those handlebar mounted shifters I suspect it's a 14 SPEED?
If so then 7 speed STi's are like hens teeth. You may be able to use 8 speed ones, (you'll just have a redundant extra click), but even if you can I have to agree with Cycleops, the cost would outweigh everything else.
I'd look into selling the Viking and upgrading via the second hand bike route.
Cheers Nigel so wat do I actually search for on Internet to purchaseDepends, 7sp can be had on ebay for £20-30.
I have all sorts of setups on mine in the last 12 months some have worked better than others.
These are a set of 8x2 sora shifters, double on the front and 8 on the rear, they will probably go for the £30-40 mark.Cheers Nigel so wat do I actually search for on Internet to purchase
