Thinking of doing more flat training in 2010 as my dead flat speed leads a lot to be desired, to say the least.
So my training bike has 28/38/48 at the back and a 7 speed freewheel 14-16-18-20-22-24-28 the gear I use most often (nearly always) is 38/20 which is around a staggeringly tiny (compared to others) 52 gear inches. The big cog gear I'm most likely to use is 65" but this is far too big for me to be able to spin properly for very long. Alternative gears I could use for flats training are 38/18 which is 57" and 48/22 which is 59".
I've found somewhere where I think I can do some stomp work or whatever but I'm unsure how long I should be doing it for, intensity and so on and especially which gear. It's not like the heart rate sky rockets to max HR in 65" either, it's just fairly painful on the legs, particularly the lower leg muscles.
So any ideas on training in the above context would be good. Cheers
. I started off in the bigger gear but at a very low cadence which was totally wrong and for the last 3 years been in small gears at pretty high cadence and it's gone higher and higher (at times). My average speed hasn't budged much the last 3 years, but I can do much longer distances.
I thought the track bikes were about 75" or something for some reason. Maybe there's hope for me yet. What I found interesting the first time in Manchester was that the timed track average was very fractionally faster than the top speed I've got on the marin on the flat.
