Flat bar into a drop bar??
Young Un
Worcestershire
hi, my dad went into a giant dealer today and picked up a catalogue for me. i was looking through the bikes drooling as you do, when i looked at both the scr4 and the fcr3. my dad looked at the bikes in person and was chatting to the lady, he also seemed to realise the fcr3 looked better spec/more sensable than the scr4. he asked the lady in the shop wheather you could make a flat bar bike into a drop bar bike with bar end shifters., and she said that it was imposible because the two use differnt mechanisms
  1. would fitting drop bars to the fcr3 make it have the same geomerty as the scr4?
  2. can it be done?
RedBike
Beside the road
Yes it can be done. Are you sure you mean bar end shifters?
I belive the two bikes use exactly the same frame, so yes the geometry will be the same. - (not 100% sure about that; but it used to be case on earlier models.)
BTW, the SCR has a really upright / high ride compared to most racers.
Young Un
Young Un
Worcestershire
your right redbike well spotted i mean the gear levers that are the same as the brake levers, cant remeber what there called
the reason for it mainly is for the triple chainset,
how much do you think the lbs would charge to do the conversion??
bonj2
Yes course it's possible, I've done it to my bike. But only 'cos I originally wanted flat bars, but then as I progressed I decided I wanted drop bars. If you know you want drop bars to start off with, then just buy a bike with drop bars to start with, it'll undoubtedly be cheaper.
I'd personally recommend STI shifters if you're having drop bars. But I got a very good deal on mine, got some unboxed OEM 105s for £40, then also need handlebars, bar tape, and I also needed new cables 'cos my old ones were ready for replacing anyway and a new cassette 'cos i was upgrading from 8 to 9 speed.
Don't necessarily limit your choice to just a Giant (although Giants are good).
You'll find some bike shops are stockists for one type of bike mainly, but you can hunt around different bike shops who will have affiliations with different manufacturers.
RedBike
Beside the road
Shifters (sora) £60
Front Mech £12
New brake cables £10
New Gear cables £10
bar tape = £10
Labour? - Could be upwards of £50 for a bike build
I would say £100 minimum, probably quite a bit more.
Young Un
Young Un
Worcestershire
thinks i might stick to the scr4 then, how much would it cost to upgrade to a triple chainset if i found that a double wasnt enough for the hilly town where i live,
also could someone tell me the order of the ranges of shimano and campagnolo
Joe24
Nottingham
No need to upgrade to a triple IMO. Go for the SCR4 and run it as double for abit. There is always the option of walking up a hill if it is really big.
the STI shifters are expensive. The Sora one i think are about £100. If you were going to use STI's i would use Tigra shifters so you can change both ways while on the drops.
But if you got the SCR4 then the Sora is fine and you will get used to it.
bonj2
I personally wouldn't touch any road bike with a barge pole that hasn't got all the following on it to start with:
a) Drop bars
:sad: Tiagra or above shifters
c) Triple chainset
I wouldn't set about butchering it or 'making do' with a double or compact chainset or faffing about with silly sora levers. But that's just me :sad::sad::angry:
Joe24
Nottingham
Bonj you fool. Real men dont need triples:becool:
Sora shifters are fine. They are made and put on for the aim of riding on the hoods more then the drops. If you are going to use the drops more then having Tigra is good, but if your going to use the hoods more(like beginners do) then they are good at keeping the cost down.
bonj2
Shimano is:
Dura-ace <-- high end
Ultegra
105
Tiagra
Sora
'numbers' e.g. 2200 <-- entry level
although 105 is being deprecated.
don't know about campag, someone else will fill you in on that
Steve Austin
The Marmalade Kid
Mlehworld
105 isn't being 'deprecated' at all. it will be going longer than you or i Bonjella ;)
I would go for the bike you want.
If you want a triple, get a triple. if you want a flatbar, get a flatbar.
Any upgrading you do will cost money, and that money would be better spent initially.
its ok to upgrade parts for better parts, but its expensive to upgrade chainsets and shifters, and its really isn't worth it.
Save your money till you have enough for the bike you want would be the best advice
RedBike
Beside the road
You've missed one
Dura-ace
Ultegra SL
Ultegra
105
Tiagra
Sora
2200
Super Record
Record
Chorus
Centaur
Veloce 10
Veloce 9
Xenon
I think Chorus is about Dura-ace standard
Xenon is about matched to Tiagra.
