As a driver, I sometimes struggle to tell the distance of a bike when the lighs are flashing, probably similar to the doplar effect. Is this just me or is this a recognised issue?
I'll add to this if one light is brighter than the other & they're close together then make sure that is the flashing light (a brighter solid light will almost completely mask the flashing dimmer light)This is why you will see many of us suggest that you use two lights, 1 flashing and 1 steady, then you get the best of both worlds.
2 lights makes sense. Am new to cycling and will be buying lights soon.
