Gixxerman
- Market Rasen
I am an engineer, so I have a good degree of mechanical sympathy. If I hear, feel or see something that is not right whilst riding, I stop and investigate. This most certainly cannot be said for my bother and his kids. My nephew left a bike at my dads house with instructions for me to take a look at it. The symptom reported was that the chain comes off when you pedal backwards. I immediately thought that maybe he was changing gear whilst back pedaling, but even he is not that silly. So I took it home to have a look. What greeted me was beyond my expectations. The bottom bracket had about 5mm of play in it. The freehub retaining ring had unscrewed completely and the freehub had fallen off the wheel. The rear wheel wobbled on its axle alarmingly. After the rear wheel was stripped. The tale of woe was that most of the free hub bearings had decided that going round and round was not for them, and had made good their escape, as was the same for the rear wheel bearings. The rear brake was almost too stiff to operate. When questioned about all this my nephew said that he was aware that the rear brake was a bit stiff, but he didn't use it anyway. He was however, unaware about the BB play. He was unaware that the free hub was in the process of falling off, until it actually fell off completely. He did think that the rear wheel was a bit lose and it was hard to reach a decent speed without a lot of effort.
Luckily, and had some ball bearings of the correct sizes for both the free hub and rear wheel. This was cleaned, greased and re-assembled and it worked quite well. The free hub still sticks a bit, but that is probably a decent result given the level of abuse it has suffered. The rear wheel now rotates without the ridiculous wobble it had. The BB was stripped, cleaned, reassembled and adjusted and it is fine now. Rear brake cable and pivots were lubricated and brake bias adjusted.
It is ridable again now. I am just flabbergasted that someone could ride a bike with these issues and not be aware that something was wrong.
