bossanovawitya
Hello all,
Hope this is the right forum within the site for this post.
Today I changed the inner tube on by back wheel which is fitted with an Alfine 8 speed hub gear - have done this many times before. Put it in 4th gear, rotated the outer of the hub to create slack on the gear change cable then disconnected it. Removed wheel. Changed inner tube. All as normal.
When putting the wheel back on something has gone wrong. Putting the no-turn washers on positions the hub with the arm that receives the gear change cable pointing upwards. I secured the wheel and put the chain on without the gear change cable and gave it a pedal. It has slipped down to the lowest gear.
Any idea how to rectify this? Don't have a clue how I'm managed to force it to change down, nor why it has caused the gear change cable receiving arm to rotate. It doesn't want to move now!
Any one got any ideas? a couple of pictures to help:
