Fixie sprocket / single speed freewheel
Boly
Regular
I plan to add a single speed freewheel to the flip flop hub of my fixie just in case I need it.
I presently run on 18 tooth sprocket and have no option but to add an 18 tooth freewheel because I have little horizontal clearance to vary the tension on my chain via the drop out length.
I am trying to ensure that the circumference of both the sprocket and the freewheel is identical. I was recently told that it wasn't ? I fail to understand how 18x32 teeth can be spread across circumferences of different sizes and allow both of them to engage with a 3/32 chain.
I hope these ramblings make sense? My fixie sprocket is 18 tooth and 77mm across between the peaks of the teeth.
B
Boly
Regular
Sorry, thank you!
Bob
rogerzilla
The chainline probably won't be the same - maybe that's what they meant. Get the fixed side right and let the freewheel side look after itself.
