Fixie or Geared
Olaf
Regular
Birmingham
Just looking to start riding again and am considering a Fixed wheel as opposed to gears.
Any thoughts or tips ??
Deleted member 1258
How long has it been since you last rode? It may be an idea to start with a bike with a flip/flop rear hub, that way you could start with a single speed with a freewheel then once you are used to riding again flip the wheel to start riding fixed.
Olaf
Olaf
Regular
Birmingham
Thanks for that, in truth its been a while. I'm on pretty tight budget any thoughts on which bike to look at ?
al-fresco
Growing older but not up...
Shropshire
I bought a Specialized Langster (fixie) last autumn and I've done 1,500 miles on it since then - in the same period I've done about 120 or so on my Surly Cross Check (18 speed). I tend to chose the Langster over the Cross Check for any journey of less than, say, 70 miles where hills aren't a big factor. I find that riding fixed gives a better workout in a shorter distance and, consequently, a bigger improvement in fitness over riding gears. As the weather gets nicer and the days get longer I expect the Cross Check will come out more for longer journeys. If I had to chose just one I would chose the Cross Check - because it will do everything. But as I'm lucky enough to have both I think the Langster will continue to get the most use - particularly in the winter.
Bigsharn
Leeds
There's a middle ground, you can go singlespeed on a freewheel hub, and not go fully fixed.
To be honest I'd go gears if you're just starting out again, that way you can find out what gear ratio (or inches) suits you best and get a fixie/singlespeed as your N+1
Olaf
Olaf
Regular
Birmingham
Thanks for the advice, like I said I'm on a budget so any suggestions on how much I should be looking to pay and any makes/models to chose or avoid
calibanzwei
Warrington
How mcuh of a budget?
Ivan Ardon
Length of commute? Frequency? Many hills? Will you do your own repairs? How shiny do you like your bike to be? Are you bothered about brand image? Are you fit? Flexible? etc etc. Lots of questions need answering before you'll get a sensible answer.
Dan_h
Reading, UK
+1 to this.
I re-started cycling regularly about 18 months ago. I began on a geared bike, but tried a single speed after about a year. I have found that i can get up loads more hills on a single speed than I thought, but I am not sure I would have found the same when I just started out. The triple I was using at that point felt quite hard work sometimes. I think that you can use a single or a fixie for just about anything (I have done rides of 50 miles + in the Chiltern hills on my single speed) but it will be harder work than with gears. If you are pretty fit to begin with then you will be fine, otherwise build up some fitness to begin with then give a single speed / fixie a try.
jim55
glasgow
i bought this to try it ,pretty cheap and its ok ,not too heavy and rides well
its this but with drop bars
http://www.ebay.co.uk/itm/FIXIE-COY...0847199921?pt=UK_Bikes_GL&hash=item2a1b5546b1
heres it when i got it
oops ,wrong pic ,obv i put the rack on
Olaf
Olaf
Regular
Birmingham
I'm reasonably fit, but it will be for leisure not commuting as yet.I have a budget of between £250 to £300. I'm not bothered about brands or image and I will be doing my own repairs and maintenance
Dan_h
Reading, UK
If you are in reasonably good shape and are using it for leisure use so are not too worried about taking a little longer to get places (due to having to push up some steeper hills!) then fixed or geared is really your choice. I can't stand faffing with gears and like the simplicity of just running a single cog so that is my favored option. £250 - £300 will get you a better fixed gear bike than an equivalent priced geared bike.
I have just bought a new bike today though, and it is a fixie, so I may be a little biased :thumbsup:
biggs682
Northamptonshire
go singlespeed its easy to convert any bike you buy that is geared , just need somebody to dish rear wheel .
so do what i and many others do pick up a reasonable old 80's racer and get rear wheel dished and you could be riding a singlespeed bike for a lot less than a new one ie sub £150
