AlanW
- Not to sure?
I've just finished building up my new track bike, and I have to admit to being surprised at just how noisy the drive train is?
Is that correct, having never had anything to do with fixed wheels before are they normally noisy than a conventional geared set up?
I have checked the chain alignment so many times, with little tweaks in each direction, and no differance?
I've altered the tension on the chain, several times, no differance?
I've even taken the chain of and refitted it the other way round, (its a KMC chain with "banana" shaped side plates) no differance?
The chain was degreased and washed then dried on the radiator then two lots of Finish Line "dry" chain lube applied, no differance?
Thoughts from the masses?
