Blimey - just entering the thread is chucking up loads of warnings and error messages! Opera is strict about things that other browsers work around. Anyway, I'll post an image and see what Opera makes of that ...
No errors there, and that worked. Try again ...
Ha - it's going to work every time now, isn't it!
Nope - caught it! Ignoring all the other things that Opera was complaining about, this error seems to be the one that breaks the image posting function:
[26/11/2011 12:53:40] JavaScript -
http://www.cyclechat.net/index.php?editor/dialog&style=2&dialog=image&_v=a23f282f
Event thread: submit
Uncaught exception: DOMException: INDEX_SIZE_ERR
Error thrown at line 1, column 146916 in <anonymous function: setRng>(i) in
http://www.cyclechat.net/js/tinymce/tiny_mce.js?_v=a23f282f:
g.selectedRange=h.getRangeAt(0)
called from line 1, column 135265 in <anonymous function: setContent>(k, j) in
h.setRng(f)
called from line 1, column 294229 in <anonymous function: mceInsertContent>(z, D, E) in
p.setContent('<span id="__mce">\uFEFF</span>',{no_events:false});
called from line 1, column 288986 in q(y, x, v) in
u(y,x,v);
called from line 1, column 266119 in <anonymous function: execCommand>(x, v, z, p) in
if(r.editorCommands.execCommand(x,v,z))
called from line 37, column 3 in <anonymous function: update>() in
http://www.cyclechat.net/js/tinymce/themes/xenforo/js/image.js?_v=a23f282f:
ed.execCommand('mceInsertContent', false, '<img id="__mce_tmp" />', {skip_undo : 1});
called from line 1, column 0 in <anonymous function>(event):
ImageDialog.update();
Ah - something else which is Interesting! I get this error message every time I press the Enter key when typing in the edit window:
[26/11/2011 12:42:58] JavaScript -
http://www.cyclechat.net/threads/fixed-pictures-in-threads.90668/
Event thread: keypress
Error thrown at line 1, column 315627 in <anonymous function: insertPara>(R) in
K.setStart(G.anchorNode,G.anchorOffset);
called from line 1, column 307702 in <anonymous function: setup>(s, t) in
if(t.keyCode==13&&!t.shiftKey&&!n.insertPara(t))
called from line 1, column 12561 in <anonymous function: dispatch>() in
f=g.cb.apply(g.scope,d);
called via Function.prototype.apply() from line 1, column 277376 in p(t, D) in
B[x[t.fakeType||t.type]].dispatch(B,t,D)
called from line 1, column 124432 in <anonymous function: g>(n) in
return l.call(j,n)
If you recall, I have previously mentioned that something odd sometimes happens when pressing Enter (text or blank lines inserted in wrong position).
Anyway, I'll leave it there for now. I hope that little lot is useful. I can still use the forum, these are just minor irritations.
