sionhughes
- Buckley, North Wales
Hi All,
Has anyone fitted SKS Chromoplastics to a Cannondale Synapse with disks before? I bought the Chromoplastics as I'd seen mention somewhere of someone fitting them a Synapse. The Synapse has front fork end mounts and rear stay mounts, but I get lost when it comes to the other mounting points. The supplied fixing to the top of the fork (where the brakes would normally be) seems to short to fit through and bolt on and the mounting hole for the top of the rear guard (again where the brakes would normally be) is 90 degrees the wrong way (i.e. facing vertically not horizontally). The mounting for the bottom of the rear guard to the bottom of the frame is also not quite right as a clip is supplied by SKS but it looks like I'll have to drill a hole in the guard to screw it in. One half of the stays are also too long on both the front and the rear.
Can anyone help with the above before I go cutting stays and drilling holes that I may not actually need as I'm being stupid?
Thanks in advance!
Thanks in advance!
