BalkanExpress
- Brussels
….I thought I would ask for your collective wisdom
The front one went on fine, well fine enough, down tube clearance is tight but I have just enough clearance and the wheel doesn't rub the guard (much).
The back one is a whole other thing. In short, If I have the end of the guard just short of touching the rear brake the stays are not long enough to remain in the bracket. If I shorten the distance by putting the end of the guard under the brake there is not enough clearance and it all jams up.
The only solution I can see is to cut an inch or so off the end of the guard so that the stays will then be long enough to hold the guard over the wheel. Of course this will give less protection, but I will see about sticking on an extra long flap...(are there any Fridays ones still knocking about?).
Before I do something that cannot be undone, are there any other suggestions?
Thanks in advance
.The front one went on fine, well fine enough, down tube clearance is tight but I have just enough clearance and the wheel doesn't rub the guard (much).
Thanks in advance
