chriscross1966
- Swindon
Hi folks, has anyone fitted "normal" brake calipers to a Brompton amongst us?.... I would really like to get Francesca fitted out with Campagnolo brakes (to match the rest of the groupset) and at the moment I can see the following issues:
1: Campys are pretty short reach.
2: Cable entry is from the top
I can solve number 1 by using 25-349 tyres and drop-nuts or brackets. I'm not going to worry about the second issue on the front fork, that's just a cable-routing problem.
On the back though I'm looking at it being an issue..... The drop-nut will buy me a little bit more space as will fitting the caliper to the other side of the triangle.... that should get me enough space for me to sleaze my way out of it with a cable noodle I think......
would welcome input from people who have attempted similar, the cable routing on Bromptons is a black art at the best of times and as I have discovered with Henrietta's 11-speed plus disc back end, once you get away from standard you will be fiddling a fair bit :-)
chrisc
chrisc
