hello I'm looking for any pointers/ tips, with drilling out the rear brake bridge, I was going to try to hand drill with a 8mm drill bit and mole grips to fit recessed brakes, the forks look straight forward enough to do
thanks
Drilling a straight and centre crosswise hole through a tube is notoriously difficult. You have one additional challenge on the brake bridge and that's getting the angle right too. Create a little jig for the job and make sure of your angles first. Start with a pilot hole and then progress with a step drill. A standard twist drill creates a triangular hole slightly bigger than nominal size.
The fork is easier, provided you have meat there to work with. That hole is perpendicular to the steerer but should be perfectly in plane. Remove the fork and clamp it securely and squarely and use a drill press, not handheld drill.
Measure twice, drill once.
Edit: Since the brake caliper will more than likely come with a flat seat at the mount bolt, you will have to find a suitable half-round converter washer/spacer in order to get the brake to seat nicely on the round bridge tube.
