fitting gear cable
young Ed
will be replacing front derailer cable very soon due to me stripping it at derailer end don't think i need to replace outer so how do i do it?
Cheers Ed
Cycleops
Accra, Ghana
Thread it through from the front, putting some grease on it, and clamp it at the changer end.
young Ed
young Ed
next question would these components fit my bike and work
http://www.halfords.com/webapp/wcs/...01&langId=-1&productId=233575&catalogId=10151
http://www.halfords.com/webapp/wcs/..._productId_186625_langId_-1_categoryId_165455
my bike
falcon trailfinder
has got the standard thumb shifter thingys
Cheers Ed
lpretro1
Yes to both - the cable will come with two different ends - select the right one for your shifter and cut the other off. When finished fit one of the little siver edn ferrules and crimp it in place - this stops the end fraying.
young Ed
young Ed
what do i crimp it with? i know it sounds stupid but i am stupid! a pear of standard heavy duty pliers, a pair of cable cutter type things?
Cheers Ed
Tim Hall
Crawley
Cheers Ed
My cable cutter type things have a wee indentation on them specifically for crimping the cable ends. Otherwise a pair of pliers might do the trick.
young Ed
young Ed
thanks will have a look and find something to do the job when it comes to it!
Cheers Ed
young Ed
young Ed
what grease should i use
no grease
lithium grease like for wheel bearings
just any sort of multi purpose grease
oh and how and where do i apply the grease?
Cheers Ed
Octet
I tend to use a small smearing of Lithium Grease.
I just place a bit between two fingers and pull the cable between them so that it gets a light coating. This basically just helps the cable move cleanly and helps it last longer.
Also, be careful when you come to cut the cable. Make sure you are using cable cutters and not wire cutters, a wire cutter will make an absolute mess of the end as they are not designed to cut through cable that thick.
young Ed
young Ed
will do thanks
Cheers Ed
Octet
I just thought I would check, you do know how to align and tune a derrialleur before you begin removing the old one?
It can be a bit daunting first time, and in some instances a real pain to get right.
young Ed
young Ed
have been playing with adjusting it and not managed to get it right yet but got a mate who is great with bikes has many and is great down the workshop! :biggrin:
oh and i got youtube :addict:
Cheers Ed
mrandmrspoves
Middle aged bald git.
Narfuk
You shouldn't need to adjust the front derailleur when you change the cable (assuming that it is set up correctly with the old cable) Definitely worth getting a good pair of cable cutters, and some cable crimps.If you buy Teflon lined cables they don't need lubing for other cables chop the inner cable close to the nipple that doesn't fit your bike, then remove the inner cable and run it through a little grease held in your hand (although my preference is to use a little engine oil as I have loads of it and I believe it keeps things smoother) before replacing the cable into the inner. Most cycles have split outers in short lengths - so make sure you use the original outers as templates and cut your lengths the same. At the end of each piece of outer, you should place a ferrule to stop the outer splaying. You may be able to remove the ferrules from the existing outers. When you cut your outers, use the old inner cable and thread it in to the outer to support the area of outer you are cutting so that the outer doesn't deform. I always use a sharp round pointed object and insert it into the cut end of the outer to ensure it is completely round.
The above may not be necessary just yet - but for the cost of a cable outer I would always replace both together.
