Fitting A Marathon Plus
Pauluk
Leicester
I've just received my Marathon + tyre from Amazon (£23.80 incl delivery) this afternoon that I only ordered on Wednesday. Good price and service I thought.
Just fitted it to my rear wheel and found it quite difficult to get on. I used the usual technique of squeezing the tyre all around to get the bead towards the centre line of the rim but couldn't get the last few inches over the rim. I did notice that the tyre seemed to have a tendency to open up so keeping the beads in the centre was tricky so I'm not sure this technique worked. In the end I just had to use a tyre lever although I don't really like doing this and have never had to do it with my other tyres.
I'd be grateful if anyone knows of an easier way to get these tyres on.
ianrauk
Tattooed Beat Messiah
Rides Ti2
May I be the first to post this vid...
P
Pauluk
Leicester
Thanks for the response ian (and smokeysmoo, its the thought that counts :smile:). I wasn't using the straps so I'll try again tomorrow with the use of my toe straps. Hopefully it won't be as hard to get off as it was to get on ^_^
slowmotion
Quite dreadful
lost somewhere
It's a wonderful video. Chapeau to Spa Cycles.
Releasable zip-ties work as well as toe straps. I think I needed about twenty when I first fitted a M+ but it gets a lot easier with practice.
MacB
Some rims are tougher than others but so far I've managed M+ without needing the straps. Nothing fancy just the Spa method but when you get near the end let the air out of the tube. This seems to make squeezing the tyre into the rim well easier and more effective. Once squeezed in I just hold the near side tight against my upper legs as I pop over the last bit.
MrJamie
Oaf on a Bike
I struggled badly the first time i fitted my M+ and feared what id do if i got a puncture away from home. The Spa video helps immensely, but ive managed to put a few on without levers since realising how much harder just a little bit of pressure in the tube makes it. Just make sure youve not trapped the tube after :smile:
avsd
Belfast
Talc powder helps a little - found summerdays advice came very naturally to me
byegad
NE England
What you have to ask yourself is. On the roadside, how do I ever repair a puncture?
Yes I know M+ are good, but I've commuted on them and they do get the odd deflation. So what do you do then? My answer, after 'The Great Evening of Swearing' as people in Stockton still call it, was to fit Pasela Tourguard tyres. Much easier to fit, very nearly as much protection and they roll better!
byegad
NE England
P.S. My knuckles did heal and the new steel tyre levers, bought to refit the tyre at the LBS in Stockton, were only ever used to get me home and remove the cursed things from my bike and my life... FOREVER!
P.P.S. I really don't like them, can you tell?????
BlackPanther
Hyper-Fast Recumbent Riding Member.
Doncaster.
Really? I've done over 15,000 miles without a puncture on M+'s, so I've only ever fitted them when I get a new bike but I swear by them on the rear. I've never managed to fit them without using a lever though. Yes, the Duraonos I run on the front of the Trice are easier to fit, but I've had a couple of punctures on them. Strapping the M+'s is essential and I use a 'trouser twist' http://www.ebay.co.uk/itm/5-PAIRS-T...Collectables_Militaria_LE&hash=item53e93bb399 which usually keeps my tool kit tightly together.....an essential piece of kit imho (both the M+'s and the trouser twists.)
MacB
good point, always do the full 360 both side making sure everything is clear, first time I failed to do this the inner tube exploded as I was pumping it up...pretty loud close to your head in a garage.
