beatlejuice
Gently does it...
- Mid Hampshire
I own a Decathlon Network 700. It has an 8 speed Shimano Alfine hub. They are quite distinct because of there unusual back end! The drive side chain stay joins the frame above the bottom bracket. I thought surely this was designed to take a belt. So throwing caution and about £150 to the wind I brought the required Gates bits.
Getting the correct alignment for the belt was a not easy. There is very little clearance for the rear sprocket. It is v close the hub. I had to put the front sprocket on the wrong way round! Comments and suggestions are welcome.
