pubrunner
Hi All,
I've a frame sitting in my garage that I'm starting to buildup into a bike.
I've acquired a brand new bottom bracket with nylon cups.
I've never fitted a bottom bracket before - other than ensuring all the threads are clean on the frame, presumably I don't need to need to do anything else before fitting ? - Do I need/should I put anything on the nylon threads ?
To clarify, The cups don't carry ball bearings on plastic. They're merely threaded holder rings for a metal shell which contains sealed bearings. The greasing I refer to, is between the plastic thread of this holder ring and the bottom bracket shell which is part of the frame.
Ta. for any advice about fitting.
