fitting a 10 speed cassette
Andrew_Culture
Internet Marketing bod
Andrew_Culture
Andrew_Culture
We're trying to fit it to replace the 8-speed groupo on Sam's (dktd) Triban 3
Andrew_Culture
Andrew_Culture
are these the stock T3 wheels you are trying to do this on?
Yup.
Pontefract
If the 8sp lockring is deeper use that, I have converted from 7-8sp, I ended up using a small toothed cogs i.e. 13th as a spacer on the spoke size as the spacer I got was to thick when it was 7sp on some RS10 wheels, 8sp fitted fine, I now have 9sp on RS11's these require a spacer (again spoke side) supplied with the wheels as its 10-11sp.
Pontefract
Any hints for indexing? The gears all snap along nicely but we can't get it onto the two biggest cogs?
Daft I know, but you adjusted the h-l stops, and tensioned the cable with the shifter in the highest gear position and pulled tight, barrel adjuster at some mid point.
A 10 sp rear sprocket is 1.6mm 9 is 1.78mm 8sp is 1.8 mm (so you can really interchange these if you want) 7sp are 1.85mm, I have used these with an 8sp, so if you have any of these on a small tooth count these can be used as spacers, not very elegant but they will work as spacers.
